Please help... Diagram needed.
Q & A for building and interfacing your rack gear with Ground Control Pro and GCX-based systems.
Post Reply
Fret-Shredder
Post by Fret-Shredder »
Could someone please draw out an easy to understand diagram for me. I want to connect 3 different preamps to my GCX and switch between them by stepping on button 1 for the first preamp button 2 for the second preamp and button 3 for the third preamp. I don't want to combine them. Only switch between them. Thank you in advance. Mike
Mike8083
Re: Please help... Diagram needed.
Post by Mike8083 »
Place each preamp in a separate loop. Going into one loop and out to the other with your guitar signal. In preset edit make sure you enable GCX and select the loop you want engaged for that preset. I assume you have enabled GCX 1?
Marlboro05
Post by Marlboro05 »
Hey Shredder,
This should help you out a bit, if you need more help, just ask.
http://www.voodoolab.mom/gcxdiagrams/04 ... werAmp.pdf
GCPro, GCX, Pedal Power 2+, Pedal Power AC.
And some other stuff.
Post Reply
